jahoosafat
Active Member
Does anyone know how to remove an SD card that's stuck in the slot of a GTN650? I can slightly push it in, but it doesn't spring release as it should. I've tried a variety of different methods, including pushing it in farther than normal with a screwdriver as well as using a pair of needle nose pliers to try to gently wiggle and pull it out. It feels locked into place (as it should be when inserted for use). I'm nervous to yank the card out in case that would break the spring/lock mechanism. Obviously, I don't really care about the card itself, but I don't want to kill the GTN. And yes, I tried to call Garmin: 30 mins on hold only to get transfered to their engineering dept, which I eventually hung up on after waiting another 30 mins on hold. Any tips are appreciated!
Jeff
Jeff
