If this doesn't work let me know
The easiest way to see (if it is a common item) what the cross referenced number is.
Go to
www.gen-aircraft-hardware.com (un-ashamed plug for my own company)
On the left side menu near the top, go to EZ Entry Order Form, click on that.
Put the number that you have in each Item Number Field, put at least 1 in qty.
Put as many numbers as you have to look up, as many as 10
You must click on "Find these products"
The Really nasty ones will come up in red, but don't give up hope, you can search from each entry by using the drop down box until you see something that most closely resembles your desired item. Click on that number and it will turn either yellow and ask you to look some more in a new drop down, or it will turn green and you should have the item that we typically stock.
The ones that come up in Yellow are recognized numbers in our system that we stock the superseding or alternate number for. You can choose on the drop down box an item that says to the right, "Typically Stocked" Once you select that it will turn green and you have a valid part number.
Once they are all green, click add to cart " don't be scared you did not buy it yet". By adding it to cart it will take you to the cart where all of your functional numbers will be.
From the cart, you can see the Part numbers and all the prices and discounts as applicable.
Load it up do it several times.
Now the good part: From the cart click on the parts numbers (they are hyper links) and it will take you directly to a rich source of information, which includes,
Part Numbers
Prices
Alternate Items
Basic Photos
Detailed Photo's
in some instances related items. IE what nut or washer typically goes with an NAS6203-12D, Try it you will like it!
The more you add to the cart the better final prices you will see.
Adding items will at some point cause the entire order to be re-priced, even for the fist item that you put in the cart.
At any time you may clear the cart or just close the screen.
Of course if you like what you see and we have what you need, we will be happy to accept your order.
Thanks for checking us out. Fellow builder RV6, Tom brink
Why does it all seem so complex? Some people are IFR in the fastener/hardware world, these are the instruments it takes to guide them to there destination without teaching a college course to each new customer.
There are many other ways to get info, depending on how you finally choose to do things.
A great way to learn of our helpful features is go to
http://www.gen-aircraft-hardware.com/site_tips.asp
