Louavul Well Known Member Sep 7, 2018 #1 Anyone know whats supposed to go in this hole, both sides of the fuselage, just below the fwd fuel tank attach of the RV-7? I've looked at a number of drawings where I would think the info should be but, keep coming up empty. Thanks,
pazmanyflyer Well Known Member Sep 7, 2018 #2 Per drawings 28 section C-10, it's called out as a 426AD4-6 rivet. Last edited: Sep 7, 2018
nilberg Well Known Member Sep 7, 2018 #3 I have to disagree with Carlos. Have a look at DWG 38, Detail F. It's the lower screw of the reinforcement angle (F-786B) that binds the bracket to the lower and auxiliary longeron. I assume it's pretty critical screw. Its a AN509 10R12 screw and you need to countersink. Last edited: Sep 7, 2018
Louavul Well Known Member Sep 7, 2018 #4 I should add it's a #10 sized hole, always has been, undrilled/enlarged.
pazmanyflyer Well Known Member Sep 7, 2018 #5 BJorn is correct. You can see in my pic is says to look at DWG 23 and 38. I missed the detail in my search today.
Louavul Well Known Member Sep 7, 2018 #6 Bjorn, you are correct, I now see it on the drawing you said. Many Thanks!!
