As Scott and several others have indicated, when done correctly, the 1" wheel works very well. I had no problems whatsoever on the scalloped edges using a 1" wheel in a die grinder. The edge quickly creates a groove in the wheel that actually helps keep things steady. And once that groove gets too deep, you just move to a clean section on the wheel. Two passes and it is done. I did go through about 3 wheels but at only $6.50 each, that is a bargain as opposed to manual methods that take much longer. I was able to do an entire rib, including lightening holes, in less than 2 minutes. No need to use other deburring tools, etc. As I think several of the other repeat builders have noted, this does not have to be absolutely perfect and shiny. Just free of burrs and smooth when a finger is run over the edge.
