I have a pretty bad misalignment at the air intakes of my James Cowl, despite trimming very carefully around the firewall and the side seams - and getting good results.
The extent of the misalignment can be seen in these photos (I wasn't able to rotate the first one - sorry)
The fix I have in mind is fairly radical so I would appreciate some peer review before I go ahead. I intend to make a cut along the black Sharpie line and pull the top half of the air intakes into the correct position where I will clamp them. Then I will lay up a strip of fiberglass over the resulting gap and when it has hardened, I will repair the gap from the inside. Finally, i will grind off the excess fiberglass from the outside.
Once the cut is opened out, I will no longer have a smooth curve across it. So there will be some extra grinding and epoxy filling required to fix that.
Does this seem like a reasonable plan? I would appreciate any comments or better suggestions and I promise to report back with photos of how it eventually turns out.
![332tnb9.jpg](/community/proxy.php?image=http%3A%2F%2Fi47.tinypic.com%2F332tnb9.jpg&hash=c07ed0f0eb8674ca2d3de8817b3c6424)
![157fyvt.jpg](/community/proxy.php?image=http%3A%2F%2Fi49.tinypic.com%2F157fyvt.jpg&hash=0fa85c20201f9f6ed36a778a26c77cc7)
