witek
Hello,
I try to find the best place for Safety-Trim ST-2-12v-2sp in my RV7A project.
I?m curious where you located this controller in your aircrafts. I have pre-cut set of harness so the location is limited by length of cables.
All suggestions or photos would be appreciated.
Witold
Under Floor Pan
I mounted mine under the passenger seat pan, one bay outboard of the center tunnel. That left access to the speed control through two small holes in the floor pan for adjustment. I'll try to dig up a picture when I can.
