about the sealing
Hi,
I've still a lot of ground to cover until I reach that point, I remember some valuable advice about the sealing though: while sealing (the safeair aluminum element against the skin) isn't necessary for it to funktion properly, one builder had problems with the inspection of the static system. After these "suction cups" where installed the test equipment indicated a leak, the "leak" turned out to be between the skin and the pop rivet though. The system was fine but the test couldn't show it because the test equipment sealed against the skin, not the pop rivet or safeair element itself.
