ONE MORE DARN THING....
Since nobody has mentioned it......what I've seen in the average hobby-ist shop ( I won't get into what I've experienced commercial screenprinting for years!!!) ....is that you only need, and use a few drops of the solvent at a time........
but.....
you open a gallon can, and for convenience, leave the cap off. It's cheap, right?
then you splash a few ounces, not drops, on a rag.
wipe..... lean right over that thing....wipe again.
set rag 'aside'.
go do something else.
come back....now the whole shop has a nice concentration of vapours from the rag, the piece flashing off, the open can.
inhale, repeat as needed, until you talk like 'Rocky'!
![Roll eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
( yo' Adrian, I don' feels so gud, y'know?)
as the smart guys have said; there's no SAFE solvent, really. Heck, I have a reaction to those strong 'orange' cleaners.
so, now up on a different soapbox....
- save your cleaning for the end of day if you can.....
- ventilate the shop while and after using solvents. That means an exhaust fan, and open window at the other end of the shop to let IN fresh make-up air.
- put the solvent in clearly labeled little squirt bottles. food grade, like contact lens solution bottles, will hold almost any solvent....and dispenses only what you need.
- gloves, goggles, obviously as needed...and don't let unprotected 'help' stand around breathing the junk you are trying to protect yourself from. tell them to go away!
- get a respirator, with carbon filters for 'organic' vapours. you're gonna need one for painting anyway, get a good one, get it fitted, don't lend it to anyone, bag it between uses, (or the expensive filters just continue to try to filter all the air in the shop!)
- rags go into a sealed metal tin immediately after use. this is a good fire precaution also.
