This thread is two parts.
Anyone used the Sabre C/S prop extension for the Sam James cowling installation? What's your thoughts/reservations.
Now that AVgas is more than $5/gal in PA, I'm strongly considering using autogas in my new RV-6. Since I'm building this from the ground up, what does it take to use autogas in the RV. I know a cooling shroud around the fuel pump is a must. Anything else to prevent vapor lock. APF system compatible with the fuels containing ethanol.
Thanks, Aden Rich.
Thanks, Aden Rich.
