update
Left early this morning, and been on the road nearly all day. Just got back.
Rhino, I had actually double-checked that, we both were using mph. Woodman, thanks for the speed mods, I hope this one wouldn?t require me having to redo the HS pitch. That?s a bit beyond my scope at this time. For now, wouldn?t even know how to check for that.
Anyway, he was a lot more informative, and had all the paper work on everything including the prop. Really nice guy, and one of the few that doesn?t mind pointing out the bad along with the good, even certain things that I wouldn?t know about until I had flown it a bit. E.g., he mentioned this one also burns more gas than most, up to about 9 gallons an hour, and I believe that was at 160 indicated in mph if I understood correctly. He?s rebuilt the carb twice, but that didn?t solve the high fuel consumption.
The prop papers show it to be a Aymar-Demuth prop with 68? length and 71? pitch. He does have a manifold gauge in it, and was familiar with the 24/48 rule that you guys talk about, so he?s probably got the mph down right.
Some time ago, when I researched some threads on Smokeyray?s props, he went through seven on his old 150 HP RV-4, and he thought the best numbers to go with for this engine set-up was 69? length and 72? pitch. Some props made quite a bit difference in speed gains. Don?t know how much this was a difference to pitch and length, or just different manufacturers. Anyway, it looks like his prop is close enough. Even so, does anybody think switching to a Hertzel, Cattoo, or MT prop might still make that much of a speed difference, particularly if I only changed the length and pitch slightly?
I think I can see some of the areas that are costing him some mph as well as maybe burning more gas. Some are just simple fixes. Like prop spinner isn?t flush around the prop, probably about an inch and a half gap all away around. Also maybe another three-quarter of an inch gap between the back of the prop spinner and cowling. Many years ago, he had a different prop on it, and just used the same prop spinner. The cowl is kind of beat up, but it seems like that is the case with just about every old RV I see. I?m not sure what I would do with that.
The fiberglass fairings where the legs meet up at the fuselage weren?t very flush, in particular the one on the left side which had a huge gap. But again, not really a big deal at all, and seems like an easy fix for that. The fiberglass tail fairings weren?t bad at all.
One thing that concerns me a bit, and might not be so easy a fix, but I didn?t like the big rudder trim. I guess it to be about six inches long, sticking out another two inches or so, with a fairly good bend in it. Seems like I read a thread where somebody undertook to correct theirs but haven?t been able to find that particular thread again. Others were also giving him numbers on how many degrees he would need to correct it. I?ll keep looking for it.
Overall, it?s not a bad looking plane at all, and the metal and paint looked good. It?s also a very lightly built plane which I liked. Part of me wants to get this plane, just for the educational aspects, and to document each change to see what mods would do for the speed. Watch me do all of the ones I suggested, and the speed still be the same.
I think this plane might work for me. It was actually the first time I even sat in a 4. Man, I could have stayed in there all day. Before I make up my mind on it, I'll get Smokeyray or find a very good A&P to give it a good look over.
