ron sterba
Getting ready to mount my NEW mwheel pant on the right main year leg. Plan drawing C-2 . Center diagram Sect-A-A and detail C.....mounted my U-808 bracket to my axle nut with a AN4-H-5 bolt. According to the Detail C it states to Safety wire AN4-H-5 bolt head to axle nut cotter pin, how is that suppose to be accomplished. Do you drill a 1/16 hole in bracket just above the bolt head and route safety wire through it to cotter pin from bolt head? Always appreciate your help. I replaced the tube and turned tire around on the rim to wear down the others side of the tire surface too.
