Norcalrv7
Found this wollowed out hole on a landing gear bracket on partially built RV-8. Thoughts?
1130171509b by Caleb Lesher, on Flickr
1130171603 by Caleb Lesher, on Flickr
![](/community/proxy.php?image=https%3A%2F%2Ffarm5.staticflickr.com%2F4580%2F23957930967_54ca2ff968_b.jpg&hash=4544405dedf45eba4acbb6d8a4c2b572)
![](/community/proxy.php?image=https%3A%2F%2Ffarm5.staticflickr.com%2F4552%2F37936198205_cb050d4514_k.jpg&hash=90218dd2e7a1c8700f322681e49eeb86)
snip...
Second, although it is a tension application, the design of the saddles precludes sufficient bolt pre-load to clamp the assembly tight. So, I'm afraid that a poor hole will allow movement of the joint. Basically, the saddles are fit so that when torqued to the rather light pre-load, the ends of the saddle are not supposed to touch the bearing plate. There is supposed to be a gap.
snip...
. . . I would consider reaming that hole smooth with an adjustable reamer, to the very minimum amount needed to get a clean hole, and then turning a thin-walled sleeve on a lathe that would be a light drive fit into the hole and provide normal close clearance hole for the bolt.
