Yes although it took a while to track down air leaks around the skirt. I ended up sticking a band of fuzzy velcro near the bottom of the skirt and no leaks since...
If you have a lot of air coming in around the back slide that's a whole other discussion, but quite doable... Check the archives for discussion...
