sailvi767
I wanted to post a bit about switching from a RV200 to a RV74 prop. We had about 250 hours on a RV200 prop. The hub was starting to spit grease on hot days so we contacted Whirlwind in Ohio. They discussed a change in seal material and grease that was causing the issue and offered to rebuild the hub and prorate the cost to their normal overhual cycle. I felt this was a fair offer and we made plans to fly the aircraft up to Ohio.
In my conversation with them they mentioned the RV74 prop they now had available. The prop was optimized for 200 to 230 HP applications. I was very happy with the RV200 blades but got a quote on the newer blades. Since the blades have to come off for the hub overhaul there were no installation costs to switch the blades. They offered a very reasonable price to switch the blades and we got to keep the RV200 blades as spares. We decided to make the change.
I flew the aircraft up several weeks ago. We did several other mods to the aircraft when we got it back and just now have been able to get a bit more hands on time with the new prop. We also had it dynamically balanced today by Mike S at Goldhill. He did a great and quick job for a very reasonable price.
The visit to the factory was interesting as they make both the Whirlwind props and the Titan Mustang kits. I enjoyed getting a chance to check out the mustangs. I noticed one was a bit larger then the Titans. He mentioned it was a full sized mustang prototype they are working on that may become a kit. I asked where they got the plans for a full sized airframe and he replied "North American". They are building the aircraft from the original plans!
The prop hub overhual and blade switch went well. The people at Whirlwind offer great support.
The prop itself looks great on the aircraft and the performance has been excellent. I typically would see 182 to 184 knots true AS in the 7500 to 9500 foot range. The new prop seems to have added about 4 knots which is a nice improvement. Today we were holding a solid 189 knots TAS at 8500 feet 100ROP. 40LOP produced 177 knots true at 8 GPH! The bigger improvement seems to be climb. The prop really pulls. Sadly I never actually timed any aircraft climbs so the increase in climb rate is subjective however both my partner and I feel the aircraft has a noticeable increase. Solo on a cold day now this thing just leaps into the air! I should have made a few timed runs and noted the conditions since when you spend money you have a desire to see a positive outcome that can color perceptions. I think there is a very noticable improvement. The prop also is very smooth since the balance. Overall we are very happy with both the looks and performance!
George
RV6, ECI IO360 10-1 pistons, Dual lightspeeds, ECI injection.
Of course!
Thanks for the report and congrats on your new blades. I'd expect nothing less from Whirlwind :)!
beautiful prop!
You mentioned that you did a few more mods in addition to the prop. Would any of them have had anything to do with the speed increases you saw? Just wondering if the speed bump was all prop or aided by the mods.
Thanks!
Russ
I just placed an order for my 74RV. Unfortunately, I have no idea what my plane's color scheme will be. I'll have to pick a generic color, so it won't be as beautiful as your prop.
beautiful prop!
Thanks!
Russ
We did add a oil separator along with the vacuum attachment from antisplat. I flew the aircraft with the new prop only once before we made the addition. I know they claim additional HP with that mod but there was some extra speed on that flight and I am skeptical about HP gains.
George
Hi George,
I am building my second RV8 here in Germany, close to Munich. I am in contact with Aerosportpower for the IO375, low compression with 195 hp and like to install the WW74RV.
1. Do you have any info that this combination could cause any trouble, especially when using the LSE ignition system and possible vibration problems for the prop?
2. Would you recommend to install a counterweight on the crankshaft?
Take any advice
Thanks for answering
Stephan
Stephan,
I am using the IO-375 with WWRV200. Before the purchase, I called Whirlwind to ask about the combination. They really liked that I had the low compression, and said that a counter weighted crank would be even better..
Randall in Sedona
74RV not too long ?
Hello,
I'm building a RV7 in France and plan to install a 74RV. My question is: There is 2 extra inches from 200RV to 74RV. Could it be a problem for a RV7 tail wheel ?
I've heard some people asked to Whirl Wind to cut 2 inches from the 74RV. Is it possible to touch the ground with a 74" ?
Any informations about that ?
Sylvain
Our engine is a ECI IO360. It is a engine that can be hard on a prop. We have 10 to 1 Pistons and electronic ignition. HP is in the 200 to 205 range. The RV74 is holding up very well. We have about 200 hours on it now and it still looks brand new. Not so much as a nick! Still love the prop however I think the initial post on speed gains was optimistic. The gain is probably more in the 1 to 2 knot range however climb is as mentioned better.
I would not be concerned with a 74 inch prop on the RV7. I think that is probably the norm on the 7 and some have 76 inch props. We are running the 74 on a RV6.
G
200HP
In my conversations with WW, they said the 74 blade is designed for 200 hp and above. I've got an IO390 with Barrett work done so it is well above 200hp.
They still recommended the 200RV for applications below 200 hp.
Aerosport power 195 HP
My IO375 from Aerosport Power is 195 HP ( low compression to burn Mogas). So it is not exactly 200 HP. Is there any body who use the 74RV with this engine ?
Sylvain
yes
I have the 74RV prop on my RV-8 with the same engine- 195hp rated IO-375 w/ low compression pistons. I originally had the 200RV installed and had to replace it due to a prop strike, so went with the 74RV blades (the hubs are identical).
I've been very happy with both props. The 74RV looks faster on the ground and gets more style points. As far as real performance goes I believe I've seen a modest increase in rate of climb and virtually no change in cruise performance vs. the 200RV.
Hi Greg,
Thank you for your reply. I saw your landing accident on your log...I think I never install a parking brake !
In a second hand, the difficulty of choosing my propeller is still there.
Sylvain
