it's a leading edge light on both wings. it doesn't have a giant old school glass bulb. It looks like an H3 but I figured I would ask before I start ripping it out to replace with an LED bulb replacement.
Wanted to see if a single H3 bulb replacement works better or if I should pull the trigger on a whole LED replacement (whelen etc.) setup.
The most common ones are probably an H3 style bulb in either a rectangular reflector, or round reflector.
The LED H3 replacements are usually not a very good solution. They either are very dim, or dont even fit into the reflector. There are some newer high power H3 LED available, but I have not played with those yet.
I installed the Rigid Industries off road LED lights. One is spot and one is flood. They are simply amazing!!! They fit in the same opening as the stock automotive fog lights. I just removed the wingtip and everything fit perfectly. Used the brackets that came with the lights.
I just did a complete change out of my wing leading edge taxi and landing lights. Went with the Baja Designs Squadron Pro lights ( 1 spot and 1 combo spot/driving)and a Perehelion wig-wag. Incredible upgrade If you are on the Vans Facebook Builders page, I posted a bunch of pics and videos.
