Fix the bounce
I struggled with this on my RV-4, your experience may be different.
Bounce is only caused by vertical speed, decent, being too high. First work at gaining more finesse at decent just before touchdown. Second, the landing gear is spring steel, it returns what ever energy is put in at touch down, if it is less than weight minus lift, you stay on ground, if it is more you bounce. Also, when you touch down with excess vertical speed, the tail goes down increasing angle of attack and increasing lift. I found that landing on one of the front wheels cuts the spring constant in half and that eliminated my bounce. As soon as I was not fighting the bounce by landing on one wheel, my finesse improved greatly.
