S sjhurlbut Well Known Member Jan 31, 2021 #1 Any pics of where you are penetrating firewall for throttle and mixture control? Seems like it has to go through centre section for alignment but I wanted to do it on far left side along with prop control. Any pics/ideas? Its tight in there :/
Scott Hersha Well Known Member Jan 31, 2021 #2 Top one is carb heat, middle one (green) is throttle, bottom one (also green) is mixture. No prop control.
S sjhurlbut Well Known Member Feb 2, 2021 #3 Thanks Thanks - looks like I can go ahead and use left side of firewall.
