sjhurlbut
Any one running a 180 hp RV4 with circular (sam james) air inlets?
The kit comes with medium sized inlet rings (4 3/8") but I'm considering the larger ones 5 1/4" for more cooling. My engine is slightly more than 180 hp.
Any data points out there or comments?
As cool as my RV-4 runs, and you're in Canada.... are you sure you have, or will have, a problem?
No
Don’t think I will just curious. Seems like the medium rings are meant for 150-160 hp RV4s.
Considering the inlet as a throttle in a system intended to raise static pressure makes no sense...but obviously folks still do it.
Not a 4, but my Rocket cools "too well" with less than 5" diameter inlets. I routinely fly in 110+ degree OAT and I dyno'd at way over 300 HP. I also have less than 27 inches of cowl exit area.
