I suggest all take a careful look at what comes in the FWF kit and delete those items that you may want replace with a different model. Such as:
- Alternator
- Oil Cooler
- Prop Governor
Carl
Going with a B&C primary and secondary alternator. Which oil cooler and prop governor would you recommend? Also, if you use a different oil cooler does it bolt on without and modification?
JIm
