mowenski
Member
Hi,
Just want to be sure on the torque value required for the oil cooler (and oil tank) In/Out flare fittings. Found 25 Nm but just would appreciate any verification.
At the time I installed my AN8 oil lines to the oil tank, the Rotax manual stated the torque was 18.8 foot pounds. I used that value for all the AN8 fittings and have not had any leaks or issues.
Happy building,
Idle hands
In Port St Lucie, Florida, for the winter. Have assembled 4 kit build aircraft last was rv8. Looking for builders in the area thanks roger t 5185783055
