barryrv10
I am helping a friend who has a RV12 registered as an E-LSA, change the registration to an AB Experimental; it has not been inspected or certified yet. We have to make some changes to it that would not allow it to be certified as an E-LSA. Do we just need to make a new application as an AB Exp with the corrected paperwork with the owner being the builder? Thanks for any help
The first thing you will need to do is cancel the E-LSA registration and start over from scratch.
Hopefully you haven't turned in an 8130-6 "Application for Airworthiness". Once the application has been turned in, the process is officially started and cannot be changed to E-AB.
