alpinelakespilot2000
As I'm trying to nail down an inspection date with my DAR (could be any day now), I've been trying to anticipate everything I can. My DAR comes with a very good reputation for doing thorough inspections, but is not, as far as I know, really familiar with RVs. That got me to thinking... are there any RV-specific items that DARs often question during inspections?. Here are three that I've run across in previous forum threads:
1. No rudder pedal return springs (just surfaced as in issue for someone here on the forum this week).
2. The 1/4" or so of play in the trim tab when using manual elevator trim cable. Every indication I've seen is that this is just the way it is and that Van's confirms that.
3. Using electrical tape connecting the brake lines to the gear legs. (I've at least added an extra layer of strapping tape around the electrical tape just because I get tired of explaining to hangar visitors that electrical tape actually is per plans.)
Others? Also, would also be curious to know the best way to handle them. For these RV-specific items, will simply showing that you've built according to drawings usually make the issue go away?
