hevansrv7a said:
But, where is Area 51? Is that another name for the RV area? That would be perfect.
Oops, I should clarify. Area 51 is THE official name for the area comprising RV parking and homebuilt camping at Oshkosh. "RV Land," "Sea of RVs," etc. and many other names as it is known by.
An EAA chapter from Michigan operates the Welcome Wagons. They are mini-vans made into open air transports. They pick up pilots and pax as they arrive in homebuilt parking and shuttle them around to various destinations on the field, like the campgrounds, bus terminal, rental cars, etc. This is a free service, but they do accept donations so throw a few bucks in the can. When you park, the parking volunteer should ask you if you require a welcome wagon, but if they forget just ask them about it.
Of course, if you arrive at 2:00PM on Sunday at the peak of arrival busyness, there may be some wait for the wagon. Welcome to the world's busiest airport. At all other times they are Johny-on-the-spot.
If you drop the wife off at the terminal, then try to get back into the taxi sequence, park your plane, then meet up again, I'm afraid you might now see your wife for a day or two. Much easier to stick together.
