Has any one of you ever flown an RV with the upper and lower fairings that go from the wing to the fuselage not installed? If so, or if you know of someone who has, would you please tell about it! Thanks!
I haven't myself but I know someone who claimed to have done it.
From his description, it was a rather frightening experience.
Not recommended.
Paul, I just know you have something up your sleeve and I'm watching to see what your mind is working on. I noted Scott's careful response so I don't think I'm alone.
Bob Axsom
But my real reason for getting confirmation of this is to point out that the same situation exists in the propeller realm. If the prop is not sealed against the spinner so that lower surface to upper surface flow can exist, the lift/thrust of the prop will go to zero in the root region and produce a vortex which affects the flow into the induction and cooling inlets, as well as creating rotational and axial drag. Sealing of a fixed-pitch prop to the spinner is very easy, since you don't have a blade swiveling on its pitch axis as you do with a CS. But take heart! It is possible to create a rotational seal at the root end of a CS prop, and I'm sure a lot of you wizards out there can figure out how to do it and increase the efficiency of your propulsion! For those of you with klunky-shaped root sections, a streamlined cuff is necessary to form the blade portion of the sealing surface. They use a cuff on some of the P-51 blades, and prop shops know how to affix them to the blades to keep them attached in flight. Let's see if some of you can figure out how make a cuff for your blades and use them to make a rotating seal! I think this should be an especially interesting challenge for those of you who want the most performance from your planes, such as those of you who race, or just want more mpg!
I understand the reasoning behind the theory, but I don't think it is valid. The blade shank of a prop near the spinner is so far away from being an airfoil that is producing any amount of thrust, that I think sealing would make no difference. It may clean up the flow around the spinner some for better flow into the cowl but I don't think it would be related to improving the low pressure area on the fwd face of the prop. I would be interesting to see some test data though...
I don't know why the thought has taken hold that there can be no thrust in a prop blade root region. That root section is following a helical path through the air just as all of the rest of the blade is, and its velocity, due to rotation, is even greater than the plane's forward velocity! Given the proper design, it will produce thrust at a very good L/D. Better that than only producing drag!
Sorry Paul, I didn't mean to imply they couldn't. I was speaking in the context of the popular propellers that are being flown on most RV's.
If it was easy to execute, I have to wonder why Hartzel hasn't done any work on this.
Many propellers on turboprop applications have blade designs more along the lines of what you describe but I imagine that each one is more of a specific application propeller. This type of thing would be very expensive for RV's
Hi, Steve! Could you elaborate a little about the type of prop, CS or fixed, and how he did it? Pix, too, if available! Also, whether he saw any cruise or top speed improvement.Hi Paul, A freind just sealed the area around a Cap-220 prop and gained 100-150 static rpm's. It was real dirty. Good idea! Steve
HI Paul,
The prop is a MPS CAP 220. The revised version of the older NSI cap 200. They are electric props. I will check with James on pictures of what he did. The spinner needs to be bigger on these props as the blade cuff sticks out of the spinner. I have a Cap 200 on my rv-6 and plan on cleaning it up. I hadn't thought of it before, but it just makes sense. I don't know about cruise improvement, but will ask. Steve
