Ok guys got something GREAT for you, A idea from Kai a RV8A builder who is just ahead of me on the mounting strips and fasteners. He asked if I had the grommet/screws/insert always falling out when you are taking on/ off the cowling (Permanent snap rings go on when the paint job is finished) and I replied WHAT A PAIN IN THE BUTT! Kai said he had the answer and you should go up to the ACE hardware store and get rubber "O" rings and just slip them over the collar of the grommet/insert to keep them from falling out. WHAT A GREAT IDEA KAI!! 20 minutes later I had the "O" rings in hand at .27 cents each or you could use baby rubber bands from a office supply house. HEY, cost of gas, just go to ACE,its the place!
Hey Robert I made my mounting strips for the bottom by buying those $2 plates and configuring them on top of a .063" sheet of 2024 aluminum. ( the seperation of the recepticale holes for the distance at the bottom cowling) then I traced around them cut out the outline on the table scroll saw. I would recommend buying from Mil-Spec the two templates for the EXACT locations of holes,templates ARE a must. When your done I would keep extra mounting plate in a drawer because no matter what, they can be used for fasteners on motorcycles,trucks bins, motor-home access doors, the list is end less! I have two pictures of the O rings as applied but have never been able to post pictures to the forums pages. If somebody wants to post them for me I will sent them the pictures on a email to them. Thanks guys.
Ron in Oregon RV9A
