Larry Parham
Any reason NOT to install the Throttle Mixture Prop on the the panel. I am going to make a new panel and I will have plenty of space, and the lower sub panel just takes up room.
thanks Larry
thanks Larry
Larry,My cables would have been too short if installed on the instrument panel. The normal mount for the throttle and mixture cable sets them back under the instrument panel about an inch. The cables in my kit did not have an inch to spare.
thanks Larry
Quadrants are a fad. One problem is that there's only one friction adjustment so you can't have a loose throttle for maneuvering and keep the others where you want them. It's easier to do fine adjustments with a vernier than with a lever. But vernier throttles are a pain for maneuvering and can be a hazard because some pilots can forget to push in the button to reduce power.
Ed
Works just great like this - and I would do it again in a heartbeat.
