Order the plans!
Hello Curt
I just can highly recommend you to order a planset from Vans for your aircraft, if you do not got them with the plane.
You have to answer yourself many question how should this looking, how is this screwed on, what is this for .... Only the plans will give you the answer how vans thought it should be done!
You are the new owner, you have to inform yourself. Don't be surprised if you find out that something is not made as vans has designed it ... check it carefully if it is just another method or if it is just a dirty fix.
As earlier in this thread mentioned, check all the Service Bulletins for your Aircraft and be sure you comply, just for your own safety. You find the Service Bulletins on Vans homepage.
Vans have the plans also on CD, so you can upload it to your device and you can carry them with you at the hangar without the paper.
All the best and enjoy your RV, it is a wonderful airplane!
