happylandings
Member
Hello all, I am in the process of purchasing an RV-9A project. The fuselage is on it's gear and the engine has been installed. I am installing a 72" wide French door in my walkout basement in order to get the fuse in for completion work. I will still need to pull the main gear legs and have the fuse on a cart of some sort with wheels narrow enough to get through the door opening. Just curious if anyone has done something like this and what the cart might look like. I have some ideas but would like to gather as much info as possible. Thanks
