Just purchased a 2008 RV9A and in the process of recalibrating the fuel tanks. Fuel quantity is indicated on an Advanced AF4500. Completed the calibration procedure on both tanks at 2 gallon intervals. On each tank the highest reading I could get was 10 gallons. Checked the resistance of Vans guages and they are 240 ohms when empty and 30 ohms after I have put 10 gallons in the tank, so they are working correctly.
I know the wing dihedral causes the guage to top out before the tank is actually full. For example, I can put 5 gallons in before the fuel reaches the bottom of the tank at the fill hole.
My specific question is, on the RV9A, how much should the guage/EFIS register when the fuel tank is full. It seems like 10 gallons may be a little low for an 18 gallon tank. If it should be more, it looks like my only option would be to pull the guages out and check the bend point in the float rod to make sure the float is not stopping before it hits the top of the tank.
Jim
Jim
