ron sterba
Have my ramps completed. Last two front panels around flywheel appear to be a inch too long. Not sure if I should trim those to be no farther forward then the teeth on the flywheel. Seems my 3 nutplates that hold the two cowl haves together are up against that baffle plate on each side of the flywheel. Does the rubber material need to be fastened that far forward? Also crossed my mind will the flywheel teeth come in contact with that plate at start up or the shut down vibration? Plans pictures are not quite close enough to get a clear picture.
How did you do it and did you modify the plate by trimming the forward edge after flying?
Thanks Guys.
Ron in Oregon QBRV9A
Thanks Guys.
