R RidiculousM Well Known Member Apr 12, 2011 #1 Hi All, can anyone point me in the direction of a really good completed build log that I could reference during the construction of my plane? Thanks, Mike Last edited: Apr 12, 2011
Don Patrick Well Known Member Apr 12, 2011 #2 I use kitlog....never had a problem with it. I know others have, but it meets all ofmy needs. http://www.kitlog.com/ Cheers
R RidiculousM Well Known Member Apr 12, 2011 #3 Don, Thanks for the correct reply to my poorly worded question. I have since edited the question. Thanks, Mike
jferraro17 Opulence, I has it... Apr 13, 2011 #4 Try these: http://www.rv8.ch/ http://websites.expercraft.com/geprevo/ http://www.kilohotel.com/rv8/ I think the first is a QB, the other two are not, but very good info, regardless. Joe
Don Patrick Well Known Member Apr 13, 2011 #5 If you browse by category of aircraft (RV-8, RV8, or RV 8) in mykitlog.com, you will find all teh builders...some of whom have completed their QB build, and others that are currently in the throws of it. Cheers, DP
G Gary Baker Well Known Member Apr 13, 2011 #6 Don't Limit Yourself... to just RV-8 websites. There is a lot of good info on other websites as well. For a quick list of websites, check out Van's Links list: https://www.vansaircraft.com/public/wwwlinks.htm Good Luck with your project!
