Very Clean Install
Couldn't help noticing the lack of a scat tube for your vents. How did you route to get it out of view? I've played with squishing it to fit between the forward baggage bulkhead and gear tower, but the brake line is also in that area.;)
At the time the picture was taken the SCAT tubing was not connected. But it is now and the only thing that is visible is a fitting on the upper left gear tower. The fitting (made from central vac fittings) splits the air flow left and right. The SCAT tubing runs to the right horizontally along the z-brace and is not visible from normal view.
wow really looks great!!
how hard is it to get the iPod out if you wanna add new songs or change a playlist?
