flickroll
I bought Jeff Jasinsky's RV-8 last fall. It was in pieces - Jeff had taken it apart for painting, but didn't get very far before he moved overseas. Tony Partain trucked it from Oregon to Virginia. I spent the last 7 months completely rewiring it, with a new panel, and reattaching wings, emp, etc. While I did not build the airplane, I now know it from forward to aft.
First off I did a few taxi tests, faster each time, until I had the tail up in the air for the last few. Then I took off, orbited the field in a climb to 5000 agl while monitoring engine gauges, etc. Today was HOT - about 95 degrees, but all engine parameters were good, although the CHT's got a little high - 425. The first landing was uneventful, a 3 pointer, full stall. Issues after the first flight:
Transponder not working. I checked the wiring and it is good, so it's either a bad transponder (GTX 327 that came with the airplane), or a bad antenna. Don't know what else it could be.
Radio according to the tower sounded a little scratchy. It is a new SL30. May need to tweak the mic gain. Any suggestions? My voice does sound scratchy in the sidetone.
The right hand fuel sender would not calibrate. The Dynon setup had me adding gas in two gallon increments. The resistance values stopped changing after 4 gallons on the right side. The left side the resistance stopped changing after 16 gallons. I suspect the left side is probably OK, just that the sender float was at the top of the tank, and with the wing dihedral, the inboard side is totally immersed while the outboard part of the tank may not be. Any ideas on the right side? Looks like changing out the sender will not be a lot of fun if that is what it is
I'm hoping the sender was stuck and flying it for a while will unstick it. Before I go to the trouble of changing it out I'll drain the tank and try a recalibration.
The last issue is the carburetor. The engine would load up rich if I did not have the mixture about half way back while taxiing. Once, when full rich and taxiing, I turned on the boost pump and the engine died. Full power it is OK. How is the carb adjusted? It is a MA 4-5, and has not had the float service bulletin completed.
