jthocker
![](/community/proxy.php?image=http%3A%2F%2Fimg83.imageshack.us%2Fimg83%2F3824%2Fn486jtinflightdl3.th.jpg&hash=cd0ca004e68521d71d5455abe07204e5)
I decided to get more air into the aircraft this way.
2 spring loaded pins on the slider rails(1 each side) when engaged prevent the canopy from siding back.
High speed taxi(6000ft rwy) and lift off at 60 knots revealed no vibration, so up and away around the pattern.
70 knots on crosswind, no vibration
80 knots on downwind, no vibration
Downwind, canopy can be closed, canopy can be opened at 80 knots
95 degree day, short final with the canopy open " My name is Jose Jimenez" (Al Shepard from The Right Stuff) I say to myself.
That flight was on Friday.
Saturday after being released from our Airport "Hot Standby Duty", First Officer Gene Seiter and I traded one 8 (DC-8) for another (RV-8).
Gene's official duty was to take notes, watch for traffic, and assess the integrity of the canopy at the rear as we explored higher speeds.
Gene has been a test pilot before also, as he has built and flown a Fisher Horizon. (An RV is in his future I believe.)
Our results so far:
110 knots with the canopy open-no adverse vibration, higher ambient noise but not enough to break the normal squelch on the intercom, volume on the radio needed to be increased slightly. Canopy, once started forward closes easily. Ventilation breezy but not a hurricane. No detectable vibration or "lifting" at the aft canopy track or slider block.
100 knots, Gene flying while I opened the canopy, using my left hand to operate the handle I could easily get the canopy open, but due to hand, wrist,elbow, canopy handle geometry it was tough to get the canopy back to the "6 inch stop" so I used my right hand to get it aft to the stop.
Gene said he detected no change in pitch or elevator forces while I opened the canopy.
I will continue to explore further but probably not much faster because
ventilation is good in the 8 above 100 knots.
