I'm working on aligning and drilling the RV8 gear legs. I have run into a snag. It appears I will need to grind the rear corner from the F-802K-1 L.G. FWD cross member in order to insert the rear NAS 6206 bolt in the U-804 outboard main gear attach bracket. You can see the problem in the photo below.
Is this normal? I expect some variation in the gear but I can't really see a way this will fit any other way. The two brackets are nearly parallel with the lower longerons in this position. I've double checked the plans but I really can't see another way.
To get this far I have attached plumb bobs to the leading edge of the gear, as well as some 6 foot lengths of RHS to the gear legs. By measuring forward and aft across the RHS I have the gear parallel. The plumb bobs line up and the gear itself is level with the rear of the fuselage with 0.25 inches.
I used a 3/16 drill bit to set the distance between the lower longeron and the outboard wear bracket as per the plans.
![2mq18af.jpg](/community/proxy.php?image=http%3A%2F%2Fi61.tinypic.com%2F2mq18af.jpg&hash=79d989be089a1e75524ffbec5f93a6f1)
![2ekngus.jpg](/community/proxy.php?image=http%3A%2F%2Fi61.tinypic.com%2F2ekngus.jpg&hash=4154f33465c64fbf84e2e3bf55775cd1)
![2qby838.jpg](/community/proxy.php?image=http%3A%2F%2Fi57.tinypic.com%2F2qby838.jpg&hash=0bad9e9b6993903719bc904b6b228fcf)
![29gbip0.jpg](/community/proxy.php?image=http%3A%2F%2Fi57.tinypic.com%2F29gbip0.jpg&hash=d0a49bf32ce549b77743680e4ebfc2f7)
