Considering the GRT Mini GA EFIS in the back seat of my RV-8. GRT makes a remote air data module (connect to air lines) that can be installed behind the panel and then wired to the back seat display so no running pitot/static lines to the back. The back seater would have indicated airspeed & altitude, a good ADI, synthetic vision, moving map and with the addition of some type of mount, all the approach stuff on an IPAD. I have both Garmin & Dynon ADSB-in which transmit via WiFi or Bluetooth for wx & tfc sent to an EFB.
According to the GRT MIni GA manual it can also input and display VOR/ILS approach data from an SL-30.
Comments on this setup or what have you done?
Anyone have a GRT Mini GA?
