Hello Everyone,
So I have a Vans RV8 and am wondering if anyone has installed the Airflow air conditioning system. Thank you all for your advice! I also have a Koger sunshade attached on the canopy... though it keeps on popping off, even after I put new sticky strips on. Been thinking of taking it all off again and forgetting it all.
1. How well does it actually work? The guy I talked to said it will deliver 25 degrees cooler temps than outside in 3 minutes. I'm fine with that, because by the time that time expires I will be done with taxi. I live in Texas so the 100+ degree heat in the summer is not fun as many of you know.
2. How easy is the install? If you have pictures of what the tubing looks like throughout the floor boards that would be greatly appreciated.
3. Have y'all had any major problems with the product? Any parts issues or something that is cheaply made?
4. Does anyone know of a better system that is available?
5. Pro's or Con's
