I'm struggling with arranging a control cable for the slide door for the fresh air vent. Can someone post some pictures or describe the routing of the cable? It seems like the scat tube is right in the way of where the cable needs to go.
I have the front baggage floor out right now redoing some wiring so this would be a good time to install a cable for the fresh air.
I'm struggling with arranging a control cable for the slide door for the fresh air vent. Can someone post some pictures or describe the routing of the cable? It seems like the scat tube is right in the way of where the cable needs to go. .
Slider door? That's actually someone's mod to the design - Van's design simply has you control the flow of air at the vents. Soo.......you're kind of on your own - whatever works!
Paul
