I would like to find out what others have done with or how they routed the bypass drain tube from the 0-360 engine fuel pump. I understand that if the engine fuel pump diaphragm develops a tear that the fuel pump will dump some fuel out of this drain tube. However, this tube is directly over the RV8 exhaust system which would create a nasty fire. What have others done with this potential issue??
