I have an RV-7a with the standard Vans cowling for a forward facing sump on a TMX IOF-360 (FADEC). My CHTs and OT run high on climb but I can manage them to keep them from red lining but want to cool them down some. I was about ready to put louvers in the bottom of the cowl then I really took a close look at the air intake area of the cowl and realized the #1 cyl. side is way too close. I don't remember anything in Vans cowl instructions about cutting the top cowl intake area back before glassing in the ramps but it looks like that is what I should have done? I can't even slide my hand up over the top of the #1 cyl. ! #2 cyl. has plenty of space.
I'm planning to pull the top cowl, cut the ramp out then cut back the intake lip on the top cowl, then glass the ramp back in to give more area for air flow over the top of the #1 cyl. - I wished I had thought of this when I did the cowl the first time!
Is that what most of you did to get better airflow?
Danny
Danny
