I would not bother messing with the filter itself unless you think it is severely contaminated. You said mixture does NOT react normally. Please explain.Kahuna,
Thank for your answer,
Air restriction! Perhaps, the van's part for IO must be modified, try without air filter?
Fuel flow max RPM rich height 53 litres normal I think.
Timing ignition verified
Lose 150t/mn with one centimeter rich poor. In this configuration the Lasar don't work it's the failure system by magneto witch work.
The mixture control have normal effect to the engine, the IO 360 is always too rich.
Are you able to go from very rich to lean and do all cylinders react accordingly? No!
Compression verified the engine have only 150hours it's a new.
No Efis on board for data.
You don't think to a propeller problem?
Thank
He said it was ground speed which given all the work he has done, its unlikely he is getting that wrong. He is missing at least 30kts with the fairings off. We are talking huge numbers here.the only real measurement of airplane performance is TRUE AIRSPEED --- indicated airspeed, and ground speed are meaningless. Without TAS numbers at various power settings and altitudes, everything else is a WAG.
53 liters/hr is 14gph which is plenty of fuel. We will assume this number is accurate.
"Lose 150t/mn with one centimeter rich poor. In this configuration the Lasar don't work it's the failure system by magneto witch work." I am not sure what this means. Translation issue?
If you are running WOT and the RPM is not exceeding its rated # to the engine, then no I do not expect there is any prop problem at all. A boat oar will do better than 130kts on a 360 running properly.
Give me these numbers:
RPM
MP
FF
Ground Speed
Altitude
2300tr/MP23 32 litres 110/130kts 2000/4000ft
2400tr/MP24 36 litres 130kts max 4000/6000ft
2300tr/MP19 29 litres 130kts max 8000/10000ft
This check was made by a mechanic with normal tools but not with the Lasar tools!
Thank
Mickael, welcome to VAF![]()
The Lasar requires a special tool to set the timing-----and the procedure must be followed correctly.
Good luck with your plane, pretty sure the VAF brain trust can sort this out for you.
Have you tried flying with another plane, which has an accurate airspeed indicator and comparing the two readings??
Are you absolutely certain the engine (ignition) is timed properly? Have seen a situation with a new plane I test flew once that had a retarded timing condition that resulted in slightly reduced power/speed. The A&P/IA multi-builder was certain the first time or two I asked him as well. It was retarded.
An very interessing answer: my RV7A have very good performance for take-of, perhaps too!
The Hartzell CS propeller supplied by Van's Aircraft is calibrated for every plane. I have this informations for my propeller, I would like to compare this values with an other owner of the same propeller. The model is: C2YR-1FBP-F7497. Thank very much for feedback information.
This informations are on the Hartzell inspection paper, it's the value of the Low and high pitch.
Is it cycling properly on your preflight? In other words, when you run the engine up to 1900 (or so) RPM with the prop full forward, and then pull the prop back, do you get a good RPM drop?
If the prop was staying in fine pitch for some reason, you'd effectively have a real good climb prop, but it wouldn't be great for speed.
When I test the CS in my preflight to 1800RPM, the RPM down but I push slowly the blue lever when the RPM arrive to 1500RPM. I don't know in this condition the exactly drop, but I can make a test next time. The take-off is always to 2700RPM at sea level, in mountain to 6500ft I can't put the full power at take-off for stay under 2700 RPM.
Wow!!! Should put mine back onI also gained 20 mph with fairings
If you slowly (say over 5 seconds) select full power on takeoff, what RPM do you reach?The take-off is always to 2700RPM at sea level, in mountain to 6500ft I can't put the full power at take-off for stay under 2700 RPM.
Not sure where all the prop concerns are coming from. Those numbers say the prop MUST be working fine.
This. I'd want to know what the GPS says on a speed run as well. My first guess reading this was that you have a pitot leak, or your pitot tube isn't aligned with the airflow properly.With these numbers I would check AS indicator and pitot system and cross check GPS speed.
Couple of things next.
1. You said "Are you able to go from very rich to lean and do all cylinders react accordingly? No!" Please tell us what it does please. This will be a clue.
2. Timing. Id like to know if the timing was checked per the manufactures requirements.
3. If 2 is yes, Id pull a mag off and view the gear timing on all accessory gears per lycoming requirements.
4. Do you have an inductive timing light and do you know how to use it?
I have flyed with fairings, it doesn't change anything.
Please don't take this the wrong way, but it would be difficult to impossible to check the internal gear timing from crank to cam by removing a mag. The simple check for this is to accomplish the test in post#22.
If the internal timing is off your mag can still be properly timed creating more confusion.
Ryan
From the OP's first post:
I find that hard to believe
I know of no RV that has not gained at least 10 to 15 MPH when fairings are installed.
Our 6A gained 16 MPH on a 4 leg course at 7500' and WOT, turning 2750RPM on a three-blade Catto, optimized for cruise speed, from 184MPH to 201MPH after all the fairings, including upper and lower intersection fairings (from fairingsetc). That's not at all unusual.
Best,
I have an appointement with a specialist equiped with contr?ler T300 for check timing with precision. Thank
I helped a friend several years ago with a very similar problem on his RV8. We had gone through many checks and tests before we came to this. I would have never guessed that an engine could run so well with the internal timming off one tooth but it will. A simple check can be performed in about 20 minuets.
First set the number one cylinder to TDC on the compression stroke.
Second, remove the rocker cover on the #2 cylinder and make sure both valves indicate closed. Move the prop in one direction you should see one rocker arm begin to move almost immediately. Rotate the prop back to TDC and try again in the other direction you should see the same on the other rocker.
If it takes several more degrees of movement on one side or the other from TDC to move a rocker you may be off a tooth in your accessory case causing a large loss in power. Easy to check. The only reason I might suspect this is the low time you indicated on your engine. It's an easy mistake to make during overhaul.
Ryan
