Sure would be a lot easier to get a tailwheel endorsement. Take a lot less time, be a whole lot more fun and cost a lot less money. Don
Has anyone done this mod and do you know if Vans puts out a conversion kit?
Also in the process of installing the 3rd engine in this beast. Hope to get it right one of these days.....![]()
Isn't that what Vans did, change their -7 to a -7A?
Here is a short list of the changes:
1. Remove engine and mount and replace with new engine mount.
2. bottom cowling (at least) modification.
3. Install main gear leg frames in cabin floor.
4. Buy and install new main gear legs and replumb.
5. replumb fuel and brake lines around and through gear leg frames.
6. remove tailwheel.
David can give you the details but it sure looks like a lot of work. Also dependent on how far along you are.
Philosophically, give the tail wheel plane a chance. I had 0 tail time when I built mine. Got the endorsement, transition training and took it slow. I'm glad I did. I have not scared myself in nearly 400 hoursI doubt there is an easier plane to fly as a tail wheel plane.
Plus, it just looks cooler!!!!
