Hello to all,
This is my first post. I've just finished rivetting the upper fwd. skin and then installed the canopy ( first time its been back on for quite a while as I was finishing the instrument panel and the electrics), you can imagine my suprise when I discovered that the curve of the aft edge of the fwd. skin doesn't match the curve of the of the fwd. edge of the canopy skin,particularly on the "corners"; The canopy skin is at least 1/16 or 3/32 proud of the fwd. fuselage skin. With hind sight I think I should have done this rivetting with the canopy in place and continuously checked the curve match.All of this matched up very well with everthing clecoed in place. Has anyone had this problem before and any ideas on an effective and aesthetic solution.
Many thanks
Mike Greene
RV7 QB
Many thanks
Mike Greene
RV7 QB
