rapid_ascent
Can anyone tell me the distance between the back of the panel to the front surface of the subpanel? Also are the bottom edges in the same plane?
I'm trying to figure out how I'm going to mount my fuse blocks. My current thinking is a hinged panel on each side that mounts the hinges to the bottom of the subpanel with quick release screws to the panel flange with some sort of appropriate bracketry.
I actually have the affordable panels modular panel, but I can figure it out based upon the standard panel dimensions.
