ChiefPilot
After putting it off for some time, I today tackled installing the steps on
my RV6A fuselage. Everything went really well, especially bending the flange around the step to conform to the fuselage (no more than 5 minutes a side). The only downside (and it's not something I did...for once!) is that the tube does not reach all the way to the F-626 web - it's about a half inch too short. This also means that I cannot pass the bolt through the F-6125 plastic block - the bolt hole is right even with the end of the tube (see pix below).
The fuse is a quickbuild fuse, so I'd expect that it's put together correctly. Some sanity measurements show that to be the case, so what I have are two steps whose tubes are too short. I can think of three possible remedies :
1) Have a longer piece of 1.5" 4130 Chrome-molly tubing welded to the existing tubes
2) Double up the F-6125 plastic blocks
3) Get another set of steps from Van's - hopefully ones with the correct tubing lengths
My preferred solution is #2, but before I go this route I was hoping some other builders might offer their thoughts on how to proceed.
Thanks!
Thanks!
