The method of identifying the strut is described in the following Van's service bulletin:I have a new U-603 nose landing gear strut. How do determine if it is the larger diameter strut? Can not see any numbers on the part.
Thanks PaulThe method of identifying the strut is described in the following Van's service bulletin:
SB 07-11-09 - Van's Aircraft Total Performance RV Kit Planes
Nose gear leg and fork upgradewww.vansaircraft.com
Hi Paul, I measured the strut per the SB you referenced ( 1.130" ) . The top of the strut has a hole drilled at the top flange. I decided not to build anymore and the kit is gone. Is this part usable or just a large door stop?Thanks Paul
Only usable if you still have the mount that it was match drilled to.Hi Paul, I measured the strut per the SB you referenced ( 1.130" ) . The top of the strut has a hole drilled at the top flange. I decided not to build anymore and the kit is gone. Is this part usable or just a large door stop?
Thanks GASMANOnly usable if you still have the mount that it was match drilled to.
