I just finished up the canopy on my RV-6 tip up canopy. When I open and close it, it seems very flimsy side to side. Is this normal and is there any way to make it stiffer?
Did you install either the wood stiffener or the RV-7 brace in/on the canopy front frame bulkhead?
In either case be sure you install guides at the base of the roll bar to prevent snagging the aft corner of the canopy on the roll bar which often breaks off the corner of the canopy.
I have a 6 and yes it is flimsy. When opening and closing, make sure to push toward the centre line as if to draw a line between the handle at the bottom of the canopy and the centre line of the canopy at the top. This makes quite a difference.
