jjglennon
Member
Hi All,
Can anyone shed light on the correct positioning of T-405, the Tank/Fuselage Attach Angle, as it is to be positioned on the inboard tank rib? The piece appears on sheets 18a and 21, but I find no dimensions or angles associated with it, except that it appears to be parallel to the bead on the tank rib. Please point me in the correct direction.
Thanks in advance.
John
Thanks in advance.
John
