Mike Buckler
Member
Just curious as to the highs and lows.
How well does a -6 with original small tail handle when flown at the high gross weights?
I've only had mine up close to 1600 and it flew and handled perfectly normal although takeoff distance and initial climb rate felt more like my old Cherokee than an RV... but once in the air it felt like it could easily handle more weight than Van's original 1600 lb limit.
I'd bet if it had 180hp and a CS prop, that the 1600 limit is way too de-rated of a number and at least 1700 would be more honestly representative of the -6's real capability.
MAXIMUM WEIGHT (Normal Category): ???????? 1800 Lbs
EMPTY WEIGHT ????????????????. 1078 Lbs
MAXIMUM USEFUL LOAD: ???????????? 722 Lbs
Set my gross at 2000 (it will take off and climb over 500'/minute with full flaps there).
Empty weight is 1088. Useful load becomes 912 (660 with full fuel).
Would allow for 2x225 passengers plus 150 pounds of baggage (200 pounds puts the CG would 2 inches aft of limit). Nevertheless, that brings it within 60 pounds.
Dan
Gross weight and therefore useful load is set by the structural design limits. It should not be set based on weight empty as built plus a desired useful load.
Just saying.
