M mikebrad Active Member Apr 5, 2012 #1 I have an RV6 that has the cork gasket leaking in the wing root. Can the access panel and cork gasket be removed with the tank on the wing
Rosie Well Known Member Apr 5, 2012 #2 Yes, it can be done Here's a thread on the screws you should read too; http://www.vansairforce.com/community/showthread.php?t=82832 Good luck! Rosie
